Hello,
Im a first time builder and want to continue to build my system out. I use my PC for Revit, not gamming, my current set up is:
Case: Corsair 600T White
PSU: AX1200
CPU: Phenom II 1035T
Motherboard: Corsshair V Formula
Hard Drive: Caviar Blue 1T/Caviat Blue 1T
GPU: Radeon HD 5700
RAM: 8GB would like to upgrade to 16
I would like to overclock, I am also thinking of going to the FX8150 and in the future switching to intell. I like the multiple cores for revit for rendering purposes (GPU doe not do much with Revit).
Id like suggestions on watercooling, should I go with a closed loop system like the corsair H80 or build a full waterloop system.
If building a system, what are the best components (Pump, radiator, resevoir, Blocks, etc.) I dont mind spending more money for better components.
Let me know your thoughts as well as any suggestions on the system I have, what would you change, or do. What would be top of the line either AMD or Intell.
Thanks
PSU: AX1200
GPU: Radeon HD 5700
Thanks
