my system is:
athlonII x4 620
4gb ddr2 ram (3pieces)
2 std Hardisk
radeon HD5850
1 dvd-rw drive
the problem is im confused in choosing budget but sufficient power supply unit for my system.
im considering on buying cooler master extreme 460w... is this ok??? or should i take the 500w of the same line??
OR... i should take other psu? suggestion plz
athlonII x4 620
2 std Hardisk
radeon HD5850
1 dvd-rw drive
