Hi all,
I'm not sure whether I'm asking this question in the correct forum, as I won't be overclocking my new chip, but since this is a cooling forum, I will give it a shot.
I'm upgrading my processor, mobo, case and cooling tomorrow, once the remainder of the parts are delivered. I went with an i7 3770k, a MSI Z77MA-G45 mobo, Arctic Silver paste, Cooler Master Hyper 212 Evo heatsink, 7 case fans and a Corsair Carbide 400R case. I'm planning to place 2 intake fans on the front and 2 on the side, then 2 exaust fans on the top (in addition to the exhaust fan on the back.)
Despite the fact that I'm not overclocking, I'm an avid daily gamer, so I do have some degree of concern about PC temps. With my current desk, I've always kept my case, which is a mini-tower case without side or top fans, inside the desk cabinet with the door closed. Please note that the back of the cabinet is completely open. This seems to have worked decently, plus it really keeps our home office looking sharp and clean.
Well, today about half of my Newegg order arrived, including the case. The 400R is a mid-tower case, so it's substantially larger than my old case. While it does fit in my cabinet, it only leaves about an inch clearance between the top of the cabinet and the bottom of the drawer above the cabinet, where I'll have two exhaust fans. This means that those two fans will be blowing directly onto the bottom of a drawer. To remedy this, I was considering taking the bottom of the drawer out (which, due to the way the desk is assembled, is pretty easy) thus making the drawer space part of the cabinet. This will give around six inches of extra clearance for the top exhaust fans. The back is still fully open, and the rear exhaust fan will be about six inches from the wall. The tower will be slid all the way to the right side of the cabinet so that the left side intake fans will have a good amount of open space. The cabinet stays closed most of the time, though, so the front intake fans will be pulling mostly from inside the cabinet, I guess.
So I guess that my question is whether this is an acceptable setup? Will the top exhaust fans need the extra space that I am planning on giving them? Will the PC be alright inside the cabinet, even with the door closed? If it is completely necessary, I can place the tower beside the desk; however, I would much prefer to keep it in the cabinet, should that not cause any heat issues.
Thanks so much for any advice!
