First Build! Double Checking
So I have been researching and posting on this forum to make sure that my first build will be a success. Here are all the parts that I am getting. Let me know what you think!!
CPU
Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
Mother Board
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131405
Hard Drive
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
I will be getting 2 of these hard drives and making them RAID 1
Memory
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
Graphics Card
SAPPHIRE 100282SR Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102857
Power Supply
Antec EarthWatts EA750 750W Continuous Power ATX12V version 2.3
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
DVD ROM and DVD+R
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
http://www.newegg.com/Product/Product.aspx?Item=N82E16827249054
Internal Card Reader
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223109
NZXT Lexa S case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146060
8 answers Last reply
More about first build double checking
  1. why dont you just buy this:
    http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.306543
    and buy this too:
    that probably saves you 200$ and gets the same things(give or take)
  2. ares1214 said:
    Why not to get this combo...
    1) ROSEWILL PSU... Not recommended!!! It will put your system at risk!
    2) Cas9 RAM vs Cas7 RAM... The OP's RAM will perform better due to the tighter timings on Cas7
    Overall, The OP has built a nice system. Just make sure to double check combos for additional savings. You haven't listed an OS but I would pick up either Windows 7 Home 64-bit or Pro 64-bit for your OS.
  3. I would switch to this memory:
    Ripjaw 1866:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231280
    $5 cheaper and speed > latency. That will help with overclocking also.
    The Samsung F3 500gb only uses one platter and is the fastest 7200rpm 500gb drive right now.
    Out of stock but can be found elsewhere:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&cm_re=samsung_f3_spinpoint-_-22-152-181-_-Product
  4. thanks ares1214 but I will be sticking with my build. I dont trust rosewell making motherboards.
    tecmo34 I will be installing Windows 7 64bit Professional. I forgot to mention that ha ha.
    Thanks cory1234 for those two links. I think im going to stick with seagate drives, but what is the difference between cas latency 7 and 9?
    Most of all will my build work as it is?!
  5. Your build will work as is...
    Difference in Cas7 and Cas9 is the speed in which the RAM processes data. Lower timings means faster response times.... (Simple Explaination)
  6. rosewill isnt making motherboards, and their psus are good for me. and the difference between cas latency 7 and 9 is speed.look at this:
    http://en.wikipedia.org/wiki/CAS_latency
    it just makes things faster and more overclockable, so always go lower. 1333 MHz 7-7-7-20 is probably comprable to 1600 MHz 9-9-9-27
  7. thanks everyone! more suggestions are still welcome. Ive learned a lot since I first started researching how to build a computer.
  8. Everything in your build will work together. Looks like you might be able to switch to an LG drive a save few dollars though. Internally many LG products are the exact same as their more expensive brother Plextor. Check out this article:
    http://www.tomshardware.com/reviews/blu-ray-dvd,2483.html
New Build Systems Product
