Front panel connections of a foxconn motherboard
i have lost my manual for my old pc. the motherboard is a foxconn. i have managed to connect everything except the cables for the front pannel, my problem is, in the motherboard there is no detailed labelling for the front pannel connector, it is just written front pannel
4 answers Last reply
More about front panel connections foxconn motherboard
  1. You can probably find the manual on Foxconn's site. If you need more help, then you should provide the model number of your motherboard.
  2. how do i determine the pins of front panel. ty
  3. more information about mother board and it parts.ty
  4. Which motherboard? Determining the power and reset pins is easy. Same for the other pins. Using trial and error won't harm the motherboard.
Foxconn Front Panel Motherboards
