Best case for air flow?
I've been looking at the HAF922 mid tower case. I like it just a few little things are putting me off. What mid tower cases are similar to the HAF922?
11 answers Last reply
More about best case flow
  1. that cooler master case is an awesome case what things are putting you off explain what you dont like about it.
  2. watched the youtube review from 3dgameman and he says that there being no dust protection at the bottom. Like i said small just wondering if there are any similar.
  3. Check this case out also a great case looks cool and has great airflow.
    Thermaltake Armor+MX VH8000BWS Black Aluminum
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811133062
  4. If you are worried about dust just buy some filters for the intakes thats all problem solved
  5. Saw a video and it rated that case as number 2. So it is good for air flow? Thought it wasn't anyway it is my favourite case. Looks better than antec models
  6. You can make your own filters out of pantyhose ive seen a few people do this and it works great me myself i dont worry about dust to much i find enjoyment out of tskeing my computer apart and cleaning every couple months.
  7. both cases are great for airflow.
  8. Little bit more expensive and technically a full tower case but laid out so it's still about the same hight as one just a little longer.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811163154&cm_re=raven-_-11-163-154-_-Product
    The mb tray has been rotated 90 degrees to allow all the parts to get fresh cold air from the bottom and have the hot air raise out the top. Basic Thermodynamics wonder why it took so long for someone to do it.
    Oh and it has dust filters lol.
  9. looking for a mid tower as i don't have room for a full tower.
    That is a very cool layout that might be my next case if i get the scratch for it.
  11. The Lian Li / Lancool Dragon Lord cases will meet your requirements - dust filters everywhere, variety of configurations, and variety of prices. Ventilation, airflow, and cooling are excellent.
    http://www.lancoolpc.com/en/product/product04.php?cl_index=1&sc_index=25&ss_index=62
    Need more bling?
    http://www.lancoolpc.com/en/product/product04.php?cl_index=1&sc_index=25&ss_index=62&num=2
    mnwave.com has the lowest prices in the USA:
    http://www.mwave.com/mwave/deepsearch_v3.asp?scriteria=lancool&ALL=y&TP=
Power Supplies Cases Components Product
