what are the 4-pins fan available for dh55tc motherboard in India with low prices?
are you looking to repalce the stock cpu cooler on the mb?? or do you need more fans for your case?? http://www.newegg.com/Product/Product.aspx?Item=N82E16835106185
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106170
these are your two low end cpu coolers..depending what sold in india i cant say as im here in the us. I would look to see if you have amazon or a large pc online store.
with case fans you have to know the size of the fans ie 90mm/120mm/140mm/
have look a db rating how loud the fan is most of the newer ones are 17db.
do u know something about computer. i m talking about cabinet cooler.
So you want a fan or fans for your cabinet that will hook up to a four pin fan header on your motherboard?
Your OP is a little hard to understand with the little info given.
