Hi everyone, got a minor problem - can't control any of my fan's speeds, and I've got 2/3 of them plugged directly into my mobo by 3 and 4 pin headers.
SpeedFan won't modify any of the speeds, whatsoever. I have a Biostar tp35d2-a7 mobo if it's any consolation...
Any ideas?
Thanks in advance!
Forgot to add, I've enabled Smartfan in BIOS...still won't let me change speed of anything.
The speeds fluctuate 10% give or take,
742-862RPM on Fan1
2450-2500RPM on Fan2 (THE ONE I WANT TO QUIET!!)
1980-2020RPM on Fan3
I *can* control the fan on my GPU though, effortlessly.
Specs are Intel Q8400 Core 2 Quad @ 3.3GHz
Idle temps 31c on each core, roughly
ATI Radeon 5700 400/900 39c idle/52c load
the Fan#2 is my side case fan, and I just want to quiet the ah heck down, maybe around 1100 rpm would be nice...
Yet another edit: I've found this Googling my mobo+fan
"Fan speed control, but only on the D2
Both boards offer automatic fan speed control for the CPU cooler, but curiously, only the D2's BIOS gives you control over temperature thresholds and actual fan speeds. On the D3, fan speed control is nowhere to be found in the BIOS, limiting users to the default configuration. One would hope, given similarities elsewhere in the BIOS, that additional fan control functionality could be incorporated into future D3 BIOS releases."
Acompanied by this picture, pretty sure you guys don't have html tags enabled...so here's a direct link
http://techreport.com/r.x/biostar-p35s/bios-fan.jpg
Basically says:
PWM Duty Off(*c) [value]
PWM Duty Start(*c) [value]
Start PWM Value [value]
Smart FAN Slope [value]
No idea what any of that means though, ideas?
Any ideas?
Thanks in advance!
742-862RPM on Fan1
Basically says:
