Hey guys!
So I just got my new computer and I am eager to OC it, Im gonna boost it to 4.2GHz. What do I tinker? The multiplier, or the clock speed? Also, should I change the voltage by a tick? Or just keep it that way?
Got the NH-U9B SE2 NOCTUA fan for the proccessor, so no problem with heat.
If I do change the voltage, to what voltage should I change it? IE, one, two, three ticks?
Thanks!
Thanks!
