matvey Distinguished Dec 18, 2009 252 0 18,780 Dec 19, 2009 #1 where to buy water block for gtx 260? please help.
Solution Shadow703793 Dec 19, 2009 Imo, don't get a full cover block. I recommend a MCW 60 + the needed MOSFET/RAM heat sinks. As for stores: http://www.dangerden.com http://www.petrastechshop.com/ http://www.sidewindercomputers.com/ http://www.jab-tech.com/ http://www.performance-pcs.com http://www.frozencpu.com/ Also read: http://www.tomshardware.com/forum/253958-29-watercooling-guide
obsidian86 Splendid Aug 5, 2009 5,762 0 26,160 Dec 19, 2009 #2 http://www.frozencpu.com/cat/l3/g30/c311/s792/list/p1/Liquid_Cooling-Water_Blocks_VGA_-_Card_Specific_-_nVidia-GeForce_260280GTX-Page1.html Upvote 0 Downvote
matvey Distinguished Dec 18, 2009 252 0 18,780 Dec 19, 2009 #3 thanks man you save my life! Upvote 0 Downvote
matvey Distinguished Dec 18, 2009 252 0 18,780 Dec 19, 2009 #4 Not Compatible with: *55nm GTX260 Cards Upvote 0 Downvote
obsidian86 Splendid Aug 5, 2009 5,762 0 26,160 Dec 19, 2009 #5 you want a full cover block? Upvote 0 Downvote
matvey Distinguished Dec 18, 2009 252 0 18,780 Dec 19, 2009 #6 yes i need full water block for 2 GTX 260 ssc Upvote 0 Downvote
obsidian86 Splendid Aug 5, 2009 5,762 0 26,160 Dec 19, 2009 #7 thats all i can find besides custom blocks, you could try asking in overclocking section Upvote 0 Downvote
Shadow703793 Champion Feb 3, 2007 15,438 0 51,160 Dec 19, 2009 Solution #8 Imo, don't get a full cover block. I recommend a MCW 60 + the needed MOSFET/RAM heat sinks. As for stores: http://www.dangerden.com http://www.petrastechshop.com/ http://www.sidewindercomputers.com/ http://www.jab-tech.com/ http://www.performance-pcs.com http://www.frozencpu.com/ Also read: http://www.tomshardware.com/forum/253958-29-watercooling-guide Upvote 0 Downvote Solution
