So when I get my new i7 PC through in a few weeks I shall be taking the plunge into custom water cooling solutions as I want decent cooling and I've came up with an idea I can't seem to find discussion on anywhere else.
Basically it involves attaching a Peltier to the water-tank with an attached microcontroller that turns the peltier on when the water hits 20o and turns it off again at 15o. May also include a... stirrer? for lack of a better word - to keep the water temperature more even and try to prevent any icing that may occur. Also attaching a heatsink to the hot side to blast the heat straight out the case instead of through it (case modding ahoy!)
I've seen peltiers can draw about 30A at 12V (400W) but I'll be using a Corsair 1200W PSU and it can easily accomodate this!
Anyone done anything similar?
