HELP WITH GAMING BUILD !!!
RESPECT YOU ALL !!!! my first post
building low cost rig. budget 500-600euros (700$)
-MB: Asus M4A785TD-V EVO (my other choise is Chorsair ||| formula, but then i have to get cheeper GPU, am not planing to OC)
-GPU: Asus HD5850 1GB DDR5
-CPU AMD phenom || x4 965 BE BOX
-RAM 4GB Corssair DDR3 1333
-POW. 550w Cooler Master
-case: Cooler Master Centurion 534
am using Asus 19" wide LCD ress. 1440x900
is this configuration worth for hi end games ?????
TUVM in advance gys !!!!
2 answers Last reply
More about help gaming build
  1. Welcome to the forum.
    Make sure that that is the 125W version of the 965.
    Make sure that that RAM's latencies (may be referred to as timings) are lower than 8.
    Switch the PSU for a Corsair 550W VX or Antec Earthwatts.
    Consider switching to a better cooled case such as the Antec 300.
    So you are aware, that computer will crush anything you play at that resolution, the next thing you upgrade should be your monitor.
  2. Thx for your response. And yes that is the 125w version of the 965. and the guy in the shop will help me with the RAM latencies so am not gonna bother you here. But i wasnt expecting that the games will crush on this ress. :( that means +200 euros for new monitor.
New Build Asus Systems
