Help with VGA and CPU and case fans
Hi! So im trying to build myself a very very silent computer and I would like some recommendations to some fans and cooling options for my CPU, graphics card, and my case fans. Here is what my computer currently has at this moment
Fractal design define XL silent case (stock fans, 2x 140mm, and a 180mm, they are a tad noisy)
ASUS P8H67-M PRO motherboard
Intel Core i5-2500K CPU @ 3.30GHz (stock fan, need a quieter solution)
XFX Radeon HD 6870 900MHZ 2GB (looking to replace the fan and heatsink, fan is very loud even at 40%, and temperatures arn't very good, 41-46C idle, 70-80C on full load)
Acepower 520W 12CM fan (very silent dont need to worry about that)
I think thats everything! I really appreciate your comments and help! Hopefully I can build myself a almost silent computer! :D
Oh yes price is no object, I can save my money for quality products (but lets not get crazy expensive lol)
1 answer Last reply
More about help case fans
  1. if you don't ran under high overclock .. stock cooler is enough and good :D
Heatsinks Cases CPUs Overclocking Product
