Hello and thanks for reading. I am currently buying parts for my very first system build and am stuck on motherboard/cpu cooler selection. Could also use advice on the remaining parts aswell. Here is the info in accordance with the new system build template posted.
APPROXIMATE PURCHASE DATE: Within the next 2 months BUDGET RANGE: $800 Before Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming primarily with web serfing
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, cpu Q6700, RAM 4 gb (2 @2gb modules) corsair XMS2 6400,MX-2 Thermal paste, antec nine hundered case, and 24' LCD
PREFERRED WEBSITE(S) FOR PARTS: Tiger direct and new egg COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: Nvidia cards. Best performance possible
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Maybe SLI.
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: Windows 7 64 bit a must.
Parts already purchased:
Corsair Dual Channel TWINX 4096MB PC6400 DDR2 800MHz Memory (2 x 2048MB)
CPU was bundled with this at the time for $249. Intel Socket 775 q6700
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
ARCTIC COOLING MX-2 Thermal Compound - Retail
So as you can see I still need a PSU, HDD, DVD/CD-RW, Motherboard, and CPU cooler. Was also thinking about an additional 120mm fan for the side of the case. The big problem im having is with a motherboard/cooler selection. $363.95 has been spent so far from my budget leaving $463.05 but if I could get the rest for about $400 my wife would be happy =) Thanks in advance!
EDIT: Forgot to mention I have a nvidia 8800gts ill be using for a bit after system is built so minus the g-card. Thanks!
