Solved
ATI HD4770 catalyst 9.11 problem
My system specs....
Intel P4 630processor@3.00GHZ(HT)
Genuine Windows XP pro
Intel original 915 G/GV motherboard
1.2GB RAM(1+256 GB Ram)
Powercolor (Tul) ATI HD4770 Graphics card(512 GDDR5, 9.11 catalyst)
500Watt PSU(Zebronics platinum series)
100GB (80 + 20 GB) HDD
Sir,
I have successfully installed my card and also the catalyst 9.11 . My problem is the CCC does not work.Whenever I click nothing happens(only the memory shoots to 70% (a/c to task manager) and then comes down). I have .net 3.5 sp2 although .net2 is required but I have tried running the CCC in .net(ver 2,3,3.5,3.5sp1,3.5sp2). Also theirs a peculiar problem none of 3DMark vers. is working. All just stops responding after the first message(The initial screen).
Please solve my problem quickly..
Thanks...
:cry: :cry:
3 answers Last reply Best Answer
More about hd4770 catalyst problem
  1. Best answer
    Have you completely removed your last card's driver ?
    1_Download and install Driver sweeper from here:
    http://www.guru3d.com/category/driversweeper/
    2_Uninstall your current driver from add/remove programs and restart
    3_Boot to safe mode and open driver sweeper and click on "ATI" and then click on Clean
    4_Reboot normally to windows and install the driver again,(You may want to install Catalyst 9.12 since its newer),after the installation restart and its done.
    Check if it helps
  2. Thanks...thanks....
    It worked.
  3. No problem :) glad to help
Radeon Catalyst Intel ATI Graphics
