Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Ultra 850W Power Supply Crackling - Need Replacement
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Ultra 850W Power Supply Crackling - Need Replacement
Best answer from obsidian86.
Ok, I'm up to my ears in annoyance right now. I have been having issues with my 850watt Ultra X3 psu since they sent it to me twice during an rma/warranty replacement situation. It makes a crackling sound and until now, I've been unable to confirm it is the psu and nothing else. This is my 3rd psu from them, as my original was a 700watt model that died and then they sent me an 850 and that made crackling sounds so they sent me another 850 and that also makes crackling sounds. I was using an asus m2n-e board and amd processor. I upgraded to an intel core i7 920 system yesterday and have even more crackling sounds but now the sound is constant. I tried unplugging all of my case fans, extra hard drives, floppy drive and dvd burner and still have the problem. I must replace this psu TODAY and need a solid suggestion for a replacement unit that I can get from microcenter. I'd like to stay at or above 750watt, as i have a ups that i just got that supports up to 865 watts. BTW, the crackling is not caused by the apc unit, it makes the crackling sound with or without it. I just need a different brand than ultra and I want to stick to $150 or less if possible. I've heard multiple rails are preferable. Please advise. Thank you.
-- MaSoP
Reply to masop
I would recommend the ocz 850w for $79.99 after rebate at newegg. It has (4) 20a rails. If you're using only one video card, go with corsair and a high single 12v rail. My ocz is very quiet; no crackling sounds from my 400w with 140mm fan.
Reply to o1die
I picked up the 750Watt version of the first link above, as it was $115. I couldn't justify another $50 for 100 Watts and figured either one would be more than what my system requires. That was the solution to the power/crackling issues I had with the Ultra X3 850Watt. I'm so glad I eliminated that problem, especially seeing I just upgraded to a nice 920 setup. Thanks for the suggestion.
-- MaSoP
------------------------------ Gigabyte GA-X58A-U3DR | Intel Core i7 920 @ 2.8GHz | CoolerMaster Hyper 212 HSF | Corsair XMS3 12GB CL 8-8-8-24 DDR3-1600 @ 1066 by Default | Sapphire RadeOn HD 4870 Vapor X 1GB PCI-E | WD Blue 640GB, 1TB and 2TB Black Drives = 9.4TB Disk Space
Reply to masop
Best answer selected by masop.
Reply to masop
There are 1939 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 2 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
