Replacing old system with "new" system, your opinions, suggestions....
Hello, my 1st post here...
I am replacing a near 9 year old build with a new one.
Much has changed since my last build, but also, much is still the same and I feel confident I will have little problem.
From my old system, other than the DVD and CD drives, all I will be able to re-use will be the Lian Li Server case.
Here is a list of what I have chosen so far:
SeaSonic X750 Gold 750W ATX12V V2.3 (power supply)
Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 (CPU)
ASUS P6X58D Premium LGA 1366 Intel X58 (motherboard)
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (memory)
I have not figured out a Video card yet, and I will only want a stand alone, but, I want the best Video card I can get for performance/value (a card that will be Over Clockable for more perfomance?) under $300.
I game a little, but mostly my daughter. I will be using the computer alot for HD video editing/watching, games, movies, internet, and work with Turbo CAD.
The LCD monitor I am using is a 1 year old Sceptre X24, which the recommended resolution is 1920x1200 @ 60Hz, which is what I have it set.
I am looking forward to all your your opinions, suggestions, lessons etc., I am also looking foward to participating in this forum.
Thank you,
Rick
I am also needing suggestions on what I should use for a hard drive, or possibly a RAID system, probably something conservative in a RAID 1 configuration?
5 answers Last reply
More about replacing system system opinions suggestions
  1. bumping my message before it dissapears...
    Hopefully I will get some suggestions...
    Rick
  2. I'm partial to the Mushkin 998691's at this point.
    If you are going to OC, suggest aftermarket cooler.
    Suggest a optical drive that does Blueray like the Plextor 320SA
    Skip the RAID and just get a 500 GB per platter drive such as the Spinpnt F3 or Seagate 7200.12 RAID 0 has little performance to offer you for your programs.....RAID 1 provided protection but so does one of these:
    http://www.tomshardware.com/reviews/hdd-backup-recovery,2450.html
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817153112&cm_re=blacx_esata-_-17-153-112-_-Product
    as for GFX ... take ya budget and look here. Possible choices around your budget highlighted.
    http://www.tomshardware.com/reviews/geforce-310-5970,2491.html
    Here's the "winners" from THG's latest (December) GFX Roundup
    Best Graphics Cards For The Money: December '09
    $50 - HD 4650
    $65 - HD 4670 / 9600 GSO
    $85 - 9600 GT
    $95 - 9600 GT / HD 4830
    $110 - GTS 250 512 MB
    $120 - GTS 250 1 GB
    $155 - HD 5770 / GTX 260
    $200 - HD 4890
    $240 - 2 x GTS 250
    $310 - No winner (HD 5850 Honorable Mention)
    $330 - 2 x GTX 260 / 2 x HD 5770
    $400 - 2 x HD 4890
    $410 - No winner (HD 5870 Honorable Mention)
    $465 - No winner (GTX 295 Honorable Mention)
    $625 - No winner (HD 5970 Honorable Mention)
    If your daughter's gameplay includes PhysX titles I'd lean Nvida but given the fact that your PC has been around 9 years, you certainly don't fit the upgrade every 2 years profile common around here, so in that case, i'd say get a ATI 5xx card.
    See this is you don't know what physX does
    http://www.firingsquad.com/hardware/batman_arkham_asylum_physx_performance/page2.asp
  3. Your going to want to make sure that your cd/dvd drives are sata. It doesn't look like the motherboard you chose has support for legacy drives.
    Wow... thanks for the heads up, I never even realized that the drives won't work...now to shop for the best drives...probably a Blue ray and one from Samsung...
    Rick
    or
    $50 - HD 4650
    $85 - 9600 GT
    $120 - GTS 250 1 GB
    $200 - HD 4890
    $240 - 2 x GTS 250
    $400 - 2 x HD 4890
    Thanks for the ton of information, alot there that will guide me in my purchases..especially all the video card information, you really made it easy to pin-point which card I should buy.
    Also thanks for the memory and Blueray suggestion, as I have always wanted to get a Blueray drive (I have a nice Samsung "Dual player" Blueray/HDDVD player for my HDTV system).
    The Video card list is now my "go-to" for choosing the new card.
    Again, thanks!
    Rick
New Build Systems Product
