Solved
Graphic card problem. Is it a goner?
Hello,
I have an 8600 GTS. I was playing a game until everything became a mosaic art. I had no choice but to close the game. The colors were fine on Window's desktop. I decided to reboot. Weird colored square boxes and lines appeared during the bootup screen. And Windows could not bootup. So, to double check, my card is fried right?
If so, may I get an advise on what card I should get?
My specs are the following,
Psu - Enermax 535w
Cpu - e6300
MB - p5nsli
4gigs of ram and 2 hard drives
I would like to know what is the best graphic card I should+can get for my comp. Any help or suggestion is appreciated. Thank you.
11 answers Last reply Best Answer
More about graphic card problem goner
  1. Best answer
    If it looks like these, it is indeed dead:
    http://www.playtool.com/pages/artifacts/artifacts.html
    As for a new card, what is the budget and is it for games?
    As a fairly cheap upgrade the HD4670 can be found for under $70 US and needs no extra power connector, and the low power 9800GT is around $110 US, anything more powerful will need one (or possibly 2) PCI-E power connectors from the PSU to power it.
  2. well sorry but ur card is going to die. maybe(probably) its gpu damaged and cannot be fixed. help your self and buy a dx11 card like 5770 or 5750 . those cards are compatible with your psu
  3. What card you should get depends on your resolution and budget. If you want something cheap an HD4670 is $50-70 and 60-70% better than your 8600GTS.
  4. coozie7, thank you for that link. It was very informative. Definitely looks like the gpu is damaged.
    As for the upgrade, I would like a gaming card and I use 1280x800 or 1440x900 resolution. My budget is $100-200. However I know I have a weak CPU, so if that matters, I don't want something too powerful where my CPU would limit the GPU ( if that makes sense).
    Also, to double check, my MB is SLI only right? But can I still use a single Ati card?
  5. Glad the link was helpful.
    Have a read here:
    http://www.tomshardware.co.uk/geforce-310-5970,review-31747.html
    As a minimum upgrade the HD4670 or 9600GT will be good but anything over the GTS250 or HD5750 would probably be a little too much.
    Also check the power needs of any card you are thinking about, if your PSU has one 6 pin power lead then only look for cards that need one, if the PSU has two, then fine, but do not stray over the top cards, higher rated units may strain the powersupply, even if it has the required two power leads.
  6. Yeah you can use an ATI card, just not 2 of them.
    If that is the old 1.8ghz E6300(likely) then yeah, not very good. If it's the newer 2.8ghz one then that's not bad. If you have the old one you'll probably want to upgrade the processor. The newer one is still ok as it is but overclocking it would be a good idea.
    Fortunately that resolution is low and even a cheap card should do quite well with it so buying both a good new processor and a good card for your resolution doesn't have to cost more than your stated budget. For $65 you can get an E5200 and OC the hell out of it. All Wolfdale chips OC very well and you should be able to get 3.3-3.5ghz just on stock cooling. Your motherboard seems like it can handle any C2D chip though so you may want to up your budget a bit and go for a decent quadcore like a Q8400($160.)
    As for video cards an HD4670 or 9600GT($50-80) would be good for that resolution. An HD4770 or GTS 250($110ish) would be great. In between those is the 9800GT or if you can find one the HD4830 at around $90.
  7. He has a 535watt Enermax PSU...meaning it is a very good PSU that can run any single-core graphics card ever made.
    He should get a 4850 for $100 or a 4870 512mb for $125 (or get them cheaper used), overclock his E6300 to 2.8GHz, and call it a day.
  8. First off, let me thank you all for your responses. They have helped immensely. For now, I think I will wait for some Xmas deals that might(hopefully) be coming up.
    Happy holidays.
  9. here'a a quick summary of THG's december round up
    http://www.tomshardware.com/reviews/geforce-310-5970,2491.html
    Here's the "winners" from THG's latest (December) GFX Roundup
    Best Graphics Cards For The Money: December '09
    $50 - HD 4650
    $65 - HD 4670 / 9600 GSO
    $85 - 9600 GT
    $95 - 9600 GT / HD 4830
    $110 - GTS 250 512 MB
    $120 - GTS 250 1 GB
    $155 - HD 5770 / GTX 260
    $200 - HD 4890
    $240 - 2 x GTS 250
    $310 - No winner (HD 5850 Honorable Mention)
    $330 - 2 x GTX 260 / 2 x HD 5770
    $400 - 2 x HD 4890
    $410 - No winner (HD 5870 Honorable Mention)
    $465 - No winner (GTX 295 Honorable Mention)
    $625 - No winner (HD 5970 Honorable Mention)
  10. I did a little peaking around and I was not able to find many good Radeon deals. I came upon this deal, GT 240 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130531
    From my limited GPU knowledge, this looks like a pretty good card (for its price) compared to the available HD4830/50 on Newegg. Should I wait for more HD48x0s offers or is this deal really good and I should snatch it now? I would really like to get a good card that will last me for awhile. A card that will keep up with me when I upgrade my CPU and monitor down the road. I'm not in a tremendous hurry to have my desktop up and running at the moment (but sooner the better).
    Thank you in advance.
  11. No, that's definitely not a good deal. There's a reason no one mentioned that card and that's because it's quite overpriced. For example the HD4830 that you think isn't a good enough deal is $5 cheaper and almost 40% more powerful.
    Here, maybe this will help;
Nvidia Graphics Cards Games Graphics Product
