Hello everyone, i just recently bought a new 5850 to replace an old 9500gt nvida card, so i installed the card plugged in the 6pin connection to the card and the power supply hooked the cables to the back of the monitor and turned on the comp, but to my surprise the screen remained black and the lights on the monitor blinked, i did everything in the manual, then i decide to buy a new power supply thinking it was power issue, after doing this and installing it, the same thing kept on happening, i decide to turn on my speakers to see if windows is running, doing this i found out it was turning on the computer just that i cant see anything not even the bios, i look inside and i see the fan on the 5850 running at normal speed. Does anyone have any issue like this can anyone help with some info please i am in need of major help here are my specs
asrock conroe1333 ddr667
intel e5200 2.5ghz
hd 500gigs
psu 650w altek
4gigs ddr2ram
note this mainboard is pci express 1.0 not 2.0 but that shouldn't affect it either
someone help thanks in advance
intel e5200 2.5ghz
hd 500gigs
psu 650w altek
4gigs ddr2ram
