Tom's Hardware > Forum > Games General > Games General Discussions > Startup problem - monitor refresh rate, resolution?
Forum Games General : Games General Discussions - Startup problem - monitor refresh rate, resolution?
Archived from groups: alt.games.the-sims-2 (More info?)
Calling all Sims2 gurus,
*How can I tell Sims 2 to use a lower refresh rate?*
On starting the game the monitor goes all bLuRy-LiNeD
Old Belinia 15" CRT monitor.
It obviously can't handle the refresh rate for the default resolution :(
Even tried running at 640x480; shortcut 'compatibility' option.
My Wife's PC stats: (she's sims1 fan, ecstatic to get sims2)
Duron 700MHz
384MB SD-RAM
GeForce 440MX 64MB
WinXP Pro
Longtime sims fan, regular on sims1 forum (ages ago).
Please excuse if this problem is well-known,
I have googled, and skimmed the 300+ messages here,
didn't find anything technical enough to answer my question.
Many thanks (from us both) for any ideas.
-DreadDave
P.S. yah, I know. Won't run good on her system, but let her try.
Sponsored Links
Hello i am not a specialist
i think the game will run under the refresh rate of your video driver
so if you go by youre desktop and rightmouse click to properties advanced
you can enter your videocard refresh mode
there you can put it for instance to 70 or 72 rate i wouldnt go lower as
then it goes blinking to much
and in resolutions you can go to 800x600
this can be done also in the sims 2 itself in options monitor
sorry for my buggy english
Greetings
"DreadDave" <dreaddave@yahoo.com> schreef in bericht
news:cvilt3$j1$05$1@news.t-online.com...
> Duron 700MHz
> 384MB SD-RAM
> GeForce 440MX 64MB
> WinXP Pro
> -DreadDave
Reply to Anonymous
"DreadDave" <dreaddave@yahoo.com> wrote in message
> Duron 700MHz
> 384MB SD-RAM
> GeForce 440MX 64MB
> WinXP Pro
Part of the problem could be that you are trying to load the game on a
processor that is less than the recommended speed. The minimum recommended
speed processor is an 800 Mhz. Even an AMD duron runs slightly slower than a
regular Athlon chipset. So I would say that almost being A+ hardware
certified, that you should consider your processor a potential problem.
Pend
> -DreadDave
Reply to Anonymous
> Pend
Hey Pend,
Yup, I do beleive you get the prise.
Got the monitor problem sorted out, but the BSOD bit me.
Just a few hundred odd MHz away from Sims2. oh well,
looks like time for an upgrade.
Thanks everyone for the answers / ideas.
-Dread
Reply to Anonymous
There are 766 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
