Tom's Hardware > Forum > Home Theatre > ReplayTV > Need Replay 45xx repair parts
Forum Home Theatre : ReplayTV - Need Replay 45xx repair parts
Archived from groups: alt.video.ptv.replaytv (More info?)
I have a ReplayTV 4508 unit that has a problem with a circuit board.
Part of a circuit board, or one of its components fried on me. The board is
the one located directly behind the outside front panel. There is a section
of this board that supports the IR function.
Anyway, everything else still works on the front cover except for the IR
function. All of the front cover buttons and indicator LEDs still work. The
replay unit itself still works. However, I can no longer use my remote
control anymore and I have to make any changes manually with the buttons on
the front cover. I guess that I should be thankful the unit itself is still
working.
I was wondering if anyone has a non-functioning 45xx unit they are stripping
and selling for parts. The ReplayTV circuit board number appears to be
LSJB3074-1.
Sponsored Links
> working.
> LSJB3074-1.
Mikeyboy on the AVS Forum.
Reply to Anonymous
"Tony D" <nospam@nospam.com> wrote in message
news:fuWdnbHLIv7me7bcRVn-hw@comcast.com...
Thanks.
I contacted him, and he sent me a price of $59 plus I have to send the old
board back to him. I was finally able to find a cheap replay 45xx unit and I
decided to purchase it strictly for parts. I have another unit, and between
both of the working units, I know that this third replay could come in handy
for future parts.
Reply to Anonymous
- 0 +
I ask again, how does Mikey get around the S/N problem? 45xx was not all
"lifetime".
I have to think a "cheap" one was monthly since the activation is the most
expensive part.
Reply to Greg
"Greg" <gfretwell@aol.com> wrote in message
news:20040825131522.16411.00001873@mb-m14.aol.com...
> "lifetime".
> expensive part.
The reply unit has several circuit boards, but I'm not talking about the
"motherboard". I was talking about the circuit board right behind the front
panel. It's related to the buttons, LEDs, and IR. :)
I fried the small part of the circuit on that board that's related to the IR
(long story). The buttons and LEDs are okay. The replay unit itself is okay,
but I can't change the channel with the remote, nor can I access any of the
hidden features any more (anything needing numbers). :(
This front panel circuit board doesn't have any effect on the lifetime
activation of the "motherboard" circuit board. It only relays signals. :)
If I replace this front panel circuit board, my replay unit should function
as normal again.
Reply to Anonymous
I would imagine the DVArchive program would give you back SOME
functionality (It has a sort of remote, however there are advantages to
the real remote too (DV-Archive's makes some assumptions which are not
always valid)
beyond that I can't much help you with board replacement
I do have a question though, which is why I changed the subject
Can you point me to a FAQ or other documentation on the "Hidden Features"
Thank you in advance remove Do.not.spam. if replying via e-mail
Reply to Anonymous
> "lifetime".
> expensive part.
It is almost never necessary to replace a mb. Most problems are zapped
tuners, modems, and net cards. Any more extensive on a lifetime
activated unit you would go through the trouble of unsoldering the eprom
with the unit firmware. DNNA seems to be more lenient than before in
swapping activations over to a new unit if it is within reason.
Reply to Anonymous
news:A6SdnSSOqaajxLDcRVn-sQ@comcast.com...
> Greg wrote:
> ...Any more extensive on a lifetime
> with the unit firmware....
Using this picture, which chip is the activation firmware?
http://img.cmpnet.com/eet/news/03/march/UTH1262.gif
Reply to Anonymous
- 0 +
I'm betting it is on the Fujitsu Flash in the lower left corner. The Molehill
site has some info on this. Larson's place.
Reply to Greg
There are 974 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
