Solved
Can you control fixed speed fans?
I guess this goes under overclocking. But i was wondering, can you control fans with fixed speeds with a program or a fan controller. Wondering because some fans have 1 set speed, and some have a variable speed.
I'm looking at these fans: http://www.newegg.com/Product/Product.aspx?Item=N82E16835200050
They are cheap and have bright led's, but everyone complains about the noise they produce. So again, can you control fans with a set speed with a program or fan controller? Thanks eveyone. :)
2 answers Last reply Best Answer
More about control fixed speed fans
  1. Best answer
    Much cheaper and better quality: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103090&Tpk=sickelflow
    Got two yesterday, they aren't very loud too.
    Yes you can control them with a fan controller.
  2. Best answer selected by OCGL16.
Heatsinks Overclocking LED Monitor Fan Controller Product
