Hey everyone! Not sure that this is the right section to post in but as usual it seemed like the most logical.
Let me set the scene. I have an NZXT Phantom 410, i5-3750k @ 4.4 GHz and currently have no graphics card due to issues that ended in having to send it back to Amazon. Within a week or two, I can add a GTX 670 to the above list. My CPU is cooled by a Noctua NH-D14 with Arctic Silver 5 rather than the stock thermal paste. PSU is the SeaSonic X-760. I think those are about all of the relevant specs.
My question really is about overall case cooling. I've read a few articles and many posts but I still don't entirely understand how to set up the case in the most efficient manner. Currently I have the stock case fans with a bit of rotating to try to maximise airflow: 120mm intake at the front, 140mm exhaust at the top and 120mm exhaust at the back. My NH-D14 pulls air from the front of the case and exhausts out the back in order to avoid drawing in warm air from the GPU. CPU idles at high twenties to low-mid thirties depending on the ambient temperature of the room. GPU idles at the warehouse, but it's the ASUS CU II if it's worth anything. Oh, and the PSU is mounted upside down as it has fanless operation when the temperatures are low - this lets the hot air escape through the fan grill when it's not spinning, correct?
I kept money aside from my budget for the purpose of buying solid case fans and I thought I'd consult the guys who always have the answers before wasting my money.
To save your time, here's what the case supports:
FRONT - 2x120mm or 1 X 140mm - bottom of the front of the case.
REAR - 1 X 120mm - top of the rear of the case.
SIDE 1 x 120mm or 1 x 140mm - ~middle, above graphics card though unsure about clearance with the new card.
TOP - 2 X 120/140mm - rear of the top of the case.
I'm really looking for the optimal setup that combines fantastic case cooling with minimal noise and I have no idea where to start. What sort of CFPM should I be aiming for; what ratio of intake/exhaust; what position for the fans?
Thanks in advance, everyone!
