Hi,
I have been having a problem with my computer and was wondering if anyone had any advice. My computer's hard drive will give off one loud click every 5-10 minutes or so. Every so often when I use a 3d program like Maya or 3dsMax the computer will suddenly freeze (no click at time of freeze) for about 2 minutes, then the hard drive will click, and everything will work again. I ran Seagate's SeaTools on it and that reported everything was ok. I am a 3d artist so I do a lot of work in Maya so this has become a real problem. I have backed up my drive, but am not convinced that it is the cause of the problem. Any advice?
Thanks!
Below is a link to the specs for my computer (it was a DIY combo buy from NewEgg)
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.755648&cm_sp=DIY_PC_Combos-_-755648-_-Combo
Thanks!
