Hi guys, I recently purchased and installed a Cooler Master 212 Plus and now I'm looking towards OCig. Specs are:
Intel i7-860 2.8 GHZ
4 GB RAM
Nvidia GTX 550 TI 2 GB
P55-GD80 Motherboard (Cooler Master 212 Plus)
Antec 900 Case
750W Power Supply
I'll be honest and say that I don't know anything about OCing but I am familiar with computers. I've read a couple of guides and how-to explanations but so far it's not sticking. Couple of questions are:
1) With the i7-860, is it possible to just raise the Hz without raising any of the voltages? Basically, can I keep stock settings but still increase performance? If so, how?
2) When overclocked, does the CPU run at that speed the whole time or only when it's required?
3) Basically any information that could help with overclocking, (Overclocking for dummies basically ) would be very helpful.
My idle temps after installation of the Cooler master were around 28-33 C and while running Crysis 2 on Extreme, temps didn't go past 45 C.
Thanks for help!
4 GB RAM
Antec 900 Case
750W Power Supply
Thanks for help!
