Help with overclocking my FX 4170
So I have my 4170 overclocked to 4500 Mhz with it's stock HSF. I ran OCCT for about 10-15 min and the temps maxed out at 56C. i have <http://www.newegg.com/Product/Product.aspx?Item=N82E168...; shipped and on its way.
Right now i just need some questions answered for assurance
First, is this overclock safe for when i play BF3 and D3 while on this stock HSF?
Secondly, what kind of improvements can i expect with this new HSF, as far as improved overclocking ability? (unless you urgently believe my purchase a mistake, don't recommend otherwise refunding my purchase)
This is the first time i OC'd a system, so take it easy on me.
Also, after overclocking from stock to 4500 Mhz, i saw great improvements in my games' framerates. Is this normal? Does overclocking the CPU open up bottlenecks on the GPU?
Sorry, this is a loaded question; i don't mind if you answer piece by piece.
FX 4170
Sapphire 6870 1 GB
Gigabyte 990 XA-UD3
16 GB Patriot 2 Memory @ 1333
Corsair Enthusiast Series 850W
OCZ Agility 3 60GB
Thank you
More about : overclocking 4170
Ask the community
