Hello,
I had a lightning strike nearby, the Asus 6T deluxe won't power up. The power supply was removed, it spins up and I have all the voltages. When installed and I plug in then swithc on the power supply I/O power supply switch, the mobo immediately flashes 2x per second, seen by the on board power and reset push buttons. The entire machine worked fine before the hit. I replaced power supplies in two other computers and revived them successfully. What does the flashing on board push button switches mean? Should I replace the power supply? I also notice that the CPU cooling fan blades pulse slightly in synchronization with the on board reset and power push button flashing. You can also hear the pulses, it sounds like little taps, it is not dead silent.
