I'm building a new system gonna go all out money isn't really an object. this will be my first adventure in to high end graphics and water cooling so would appreciate some advice my only prerequisit for the cooling system is that it has to be contained within the case preferably somthing that would sit in the drive bays. it also only needs to deal with the graphics cards as i've decided to cool the cpu seperatly using the corsair h50
spec for the machine so far are:
- Asus P6T7 WS SuperComputer X58 Socket 1366 CEB Motherboard
- 2x Corsair 6GB (3x2GB) DDR3 1866MHz Dominator GT i7 Memory Kit with Airflow Fan CL7(7-8-7-20) 1.65V Unbuffered Non-ECC
- Corsair Obsidian 800D Case - 3x 140mm Fans with 4x Hot-Swap Hard Drive Bays
- Corsair 1000W HX PSU
- Intel Core i7 975 Extreme Edition 3.33GHz Socket 1366 8MB
- 4x Western Digital WD1500HLFS 150GB Hard Drive SATAII 10000rpm 16MB Cache
- corsair hydro series h50
- 3x Gainward GTX295 1792MB GDDR3 Single PCB Dual DVI Out
- 6x dell 2209WA 22" monitors
as i said any advice is appreciated thanks
