G
Guest
Guest
Well.. . I just got this computer in through the mail and installed windows 7 on it for the first time.. But the video card it came with isnt really working so well.. i had to put my old one in from my last computer... but lets skip to the chase...
Its a RADEON HD 4870 512.. I plug both power supply 6 pin plugs into the end and slide it into the motherboard slot and bolt it into place... And start the computer up... The Moniter stays black as the computer boots up... The computer still passes the post startup thing. But nothing displays on the moniter AT ALL. The moniter is an ACER of some sort... Flat screen.. using the white hookups to plug into the Vcard... But when i put the other Vcard in it works just fine.. I dont smell anything on the radeon but it isnt working.. Perhaps im doing somthing wrong..? any help?
