Alright, Now i am very upset! i dont know whats wrong, my system doesnt tell me whats wrong and i again had a reboot.
THIS IS NOT ACCEPTABLE!
here is what happened guys,
i was working with a newly made file with minimal resolution of 72dpi and file size 960x700 (not much with 1mb initial size.)
had put up a few layers with minimal colours and nothing too graphically rich.
trued to move around the text and stuff and applied few styles to the same for effects and all and suddenly it stopped responding with a pattern of black and white thin vertical stripes filled the screen! [now if it was a PSU failure, do you think this would have happened?]
in Even Logs, there is nothing mentioned besides the last system shut down was at 16:30 and it was unexpected. but there is no log of 16:30 or even uptill 16:10 ... there is no system log in event viewer, though there is one thing i found in Event Viewer which says the following ...
Log Name: System
Source: Application Popup
Date: 26-12-2009 16:36:04
Event ID: 1060
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
\??\C:\Program Files (x86)\GIGABYTE\ET6\atidgllk.sys has been blocked from loading due to incompatibility with this system. Please contact your software vendor for a compatible version of the driver.
Event Xml:
<Event xmlns="
http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Popup" />
<EventID Qualifiers="49152">1060</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2009-12-26T11:06:04.318144300Z" />
<EventRecordID>10503</EventRecordID>
<Channel>System</Channel>
<Computer>RabbitsFoot</Computer>
<Security />
</System>
<EventData>
<Data>
</Data>
<Data>\??\C:\Program Files (x86)\GIGABYTE\ET6\atidgllk.sys</Data>
<Binary>000000000200300000000000240400C0000000006B0300C000000000000000000000000000000000</Binary>
</EventData>
</Event>
AND this ...
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 26-12-2009 16:33:03
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2009-12-26T11:03:03.132825700Z" />
<EventRecordID>10388</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Thats about it. everything else is a generic error. so where is the problem??? (i guess i will try playing a couple of games and see if its a hardware problem or drivers ... but til than any other help???)
Thanks ...
