How do i know what kind of power supply i will need
arlenek79
Hello,
i have a presentation on power supplys and my question is what does the type of power supply u use depend on is it the motherboard?
No. There are two questions here: brand and power capacity. Some brands are simply better than others. A good 400 watt power supply can produce more useful power and a poor 600 watt power supply.
Power capacity is a different matter. That depends largely upon CPU and graphics card choice. Motherboards use comparatively little power.
This should answer your question:
http://www.antec.outervision.com/
As you can see, all the components need power....base MoBo might draw 38 watts, CPU - 130 watts, GFX card - 200 watts ... add em up, account for loading and aging and you have a wattage req't.
