Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Dearly needed: power supply advice!
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Dearly needed: power supply advice!
Best answer from Keiki646.
Hi friends,
I've been really confused about what type of PSU I need--when I built my first gaming rig in 2003, I slapped some $18 dollar PSU in it and never thought about it again. Now, having just built my second rig, I have a spare 430W Thermaltake PSU in it, and am wondering if I need a more powerful PSU...
I've looked around on review sites, for a good recent round-up of PSU reviews, but a lot of the round-ups seem really dated, so any help would be appreciated! One request: please explain your reasoning behind your suggestions--I'd like to try to understand all this important PSU stuff, too!
Here are the specs of my new gaming rig (note: gaming, but I don't plan on overclocking):
With this set-up, what power supply should I get? I'm not interested in spending tons, so, though I want to buy a PSU that will protect this investment, and not fry it, I'm not looking for anything fancy, either.
P.S. Additionally, the above just said, if, at some point down the road, when this rig begins to age, I wanted to run a second graphics card in it, then what type of PSU would you recommend, too?
Reply to Hastibe
P.P.S. What do people think about this one? CrossFire Ready, too...
OCZ ModXStream Pro OCZ500MXSP 500W
Or one of these?
XION XON-630P12N 630W
AZZA Dynamo 650 650W
Eagle Tech ET-PSVT600E 600W
Message quoted 1 times
Message edited by Hastibe on 03-02-2010 at 07:21:11 AM
Reply to Hastibe
Or one of these?
Sorry but the choices that you has pick out is not what I would go for.
Reason why Xion , AzzA and Eagle are not the best. Now that OCZ that you pick out would do nice.
It's 80 PLUS BRONZE Certified switch is not bad at all. Not to sure in crossfire if you're planning in the future.
Now if you are going to do CrossFire, you should be looking into 600 watts and up. I would say a 650 watt like this one
http://www.newegg.com/Product/Prod [...] 6817139005 and make sure you pick a PSU with Active PFC
Stick with the OCZ 500watt PSU..why? it's a Modular PSU with a Actice PFC at 500 watts at the price of $89.99 and after rebate of $25.00
you only pay $44.99. Also note that it's 80 PLUS BRONZE Certified.
Message edited by Keiki646 on 03-02-2010 at 10:10:28 AM
------------------------------ イム大阪から
http://valid.canardpc.com/cache/banner/2038374.png
Gigabyte GA-P55 USB3.0|Intel i5 750 @ 4.4Ghz (O.C)|AZZA Solano 1000 Black Case|G.Skill 12GB 1600MHz DDR3|5850 @1GHz/1300
Reply to Keiki646
http://thermaltake.outervision.com/Power Check this out. Even including overclocking to 3.6ghz and using my Antec 1200 with 7 120mm led fans and a 200mm top fan as a base to go by your system draws 303w.
This is all you need and is a great power supply. http://www.newegg.com/Product/Prod [...] 6817139003
The brands you had listed are mostly junk that I would not use. The OCZ is the best of the bunch but not really impressive. Corsair is known for good quality units that are rated very conservatively.
If you later wanted to run 2 5770s you might want to look at the 550 watt version.
You said you looked at review sites and didnt find any good ones.......try here http://www.jonnyguru.com/index.php
Message edited by anort3 on 03-02-2010 at 10:05:13 AM
------------------------------ i7 2600K @ 4.5/P67A UD4/Scythe Mugen 2 Rev B/OCZ Vertex 2 120GB/2xWD 640 Blacks/Antec 1200/Samsung 23in LED LCD/EVGA GTX 460/2x4GB GSkill Ripjaws X DDR3 1600 7-8-7-24/Windows 7 Ultimate x64/Corsair 750TX
Reply to anort3
I think you need to look at the Price, Rebate, Certified and PSU watts first before replying to this topic.
That PSU that you pick out is only 80 PLUS Certified Active PFC and not 80 PLUS BRONZE Certified.
80 PLUS BRONZE Certified is much better than 80 PLUS Certified.
You're down graded him there. The OCZ 500 PSU 80 PLUS BRONZE Certified $89.99 has a better rebated of $44.99 after a 25.00 dollars rebate with 50 more watts.
To make things better it a it's SLI/CrossFire Ready and a Modular PSU, so he can only use the cables that he needs to use for this system.
Just a friendly reminder that to do your research a little better next time.
Message edited by Keiki646 on 03-02-2010 at 10:25:03 AM
Reply to Keiki646
Thanks so much for both of your responses! I really appreciate it!
Okay, so no to the weird brands (*sigh*)! If the OCZ is one that y'all would go with for my rig, and if I want two graphics cards via CrossFire to be an option in the future, should I spend the additional money to get one of these?
OCZ StealthXStream OCZ600SXS 600W
OCZ ModXStream Pro OCZ600MXSP 600W
If I should spend the additional money to get a 600W PSU for CrossFire possibilities, any thoughts between these two or comparably-priced (with the rebates) competitors? Would it be worth it to spend $60 instead of $50 to get the 86% instead of 80% efficiency that the ModXStream version boasts?
Message edited by Hastibe on 03-02-2010 at 02:23:56 PM
Reply to Hastibe
OCZ ModXstream Pro OCZ600
Reply to Keiki646
I wouldn't buy either one of them. If you look at the specs for the SXS, you have no idea what the maximum 12 volt current it can supply is. It's is certainly not not 72 amps (864 watt's ). The MXSP provides a maximum of 42 amps. That's a little light for a truly good 600 watt power supply.
A pair of 5770's needs about 13 - 16 amps. So one of these would work:
Corsair 550VX (41 amp 12 volt rail)
http://www.newegg.com/Product/Prod [...] 6817139004
If I were using a pair of 5770's, I'd go on size larger and use one of these:
Corsair 650TX (52 amp 12 volt rail)
But then, with my military electronics background, I tend to over spec power supplies.
Reply to jsc
Here are the official ATI power supply requirements for the ATI Radeon HD 5770 and 5750 video cards:
450 Watt or greater power supply with one 75 watt, 6-pin PCI Express® power connector recommended
600 Watt or greater power supply with two 75 watt, 6-pin PCI Express® power connectors for ATI CrossFireX™ technology in dual mode
The recommendations are for an entire pc system.
Corsair and Seasonic are two of the brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty. Lately we've been seeing a few other brands offering some high quality units.
Reply to JohnnyLucky
OCZ has no Bronze rated units.
http://www.80plus.org/manu/psu/psu [...] =55&type=2
Reply to delluser1
Why the ModXStream Pro and not the other OCZ one? I'm not challenging you, just curious: the +6% efficency will make that much of a difference?
Reply to Hastibe
jsc, for the SXS, on this forum, another poster said that the max amps across all the rails the SXS can deliver is 44A. I'm not sure where/how he found that out yet, but on page 3 of the manual for the SXS it does say that the max overcurrent limit for the 12V1 and 12V2 (combined) is 48A and for 12V3 is 20.5A and 12V4 is also 20.5A... Does that mean anything, concerning figuring out what the max 12 volt current it can supply is around?
Reply to Hastibe
OCZ ModXStream Pro OCZ500MXSP 500W would be good I have the 585W
lots of power !
Reply to spentshells
Best answer
You ask me to pick one that would be good and I pick the OCZ
I read about the item and it also have Typical load 86% Efficiency and Energy-Efficient 80 PLUS Certified . The other OCZ wasn't Certified.
I only pick PSU that have Certified and have good typical 85% or higher efficiency.
I have a XIGMATEK 650W ATX12V Ver.2.2 / EPS12V Ver. 2.92 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC at 87% Efficient 80 PLUS Certified. It also has Japan Electric Capacity, Completed protection OVP / OCP / OPP / UVP / SCP / OTP and Multiple +12V Output.
I had this PSU for most 2 years without any problems.
Now Corsair is another good brand name but I understand what you are looking for. You're on a budget and you need a good PSU. Not quite sure if everyone here is understand why you pick those PSU. You only have enough to pick a good PSU for a very good price but you don't want to break the bank in finding one. You'll like to get one of these PSU because that is what you are looking for. Plus is has a great rebate.
I would pick the OCZMODX if it was me. I'll also told you that is a Modular PSU , you can used the cables that you need.
Message edited by Keiki646 on 03-03-2010 at 12:49:22 AM
Reply to Keiki646
Does even look like an Official page....Check on the link I have post. By newegg
Reply to Keiki646
Hmm, so, are y'all sure I can't just use my 430W Thermaltake PSU for my build? The PSU provides 18A on the +12V rail...
My graphics card (HD 5770) says it needs a 450W PSU, and these power consumption tests by Xbitlabs indicate that the HD 5770 needs about 7 amps at max load. My CPU (Athlon II X4 930) requires 95W (at least, that's what it lists under "Thermal Design Power" on the AMD site), which translates into 8 amps (right?)... Is there anything else that's going to be on the +12V rails (DVD/hard drives, RAM, or motherboard)?
Because, if not, then the total +12V requirement for gaming on my computer would be 15 amps, which means an 18A +12V rail should be fine, right?
(Or did I miss something or would 15 amps be stressing it an 18A max load too much?)
Message edited by Hastibe on 03-03-2010 at 01:06:16 AM
Reply to Hastibe
Type www.80plus.org into your address bar and do the research.
Reply to delluser1
Ok because that page looked a little fishy but maybe that site is not up to date
Every online retailer has it listed as 80 PLUS Certified
Message edited by Keiki646 on 03-03-2010 at 01:05:53 AM
Reply to Keiki646
Look at the spec on the OCZ Mod X 600PSU
+3.3V@25A,
+5V@25A,
+12V1@25A,
+12V2@25A,
-12V@0.3A,
+5VSB@2.5A
We are only here to help, it's up to you to make the choice on what PSU is good
Message edited by Keiki646 on 03-03-2010 at 01:13:43 AM
Reply to Keiki646
80+ is not 80+Bronze
Reply to delluser1
I know that was my mistake but the load efficiency is 86% 80 PLUS Certified and Modular
of that 500 watts that we talk about earlier.
But they are all 80 PLUS Certified with Loads of 85% to 86%
He is on a budget and I can tell on the way he he talking. We need to help him make a good choice
with the OCZ he can spend about 74.99 and send in the rebate of 25.00.
But I think his limited is $90 Dollars. He picks out the PSU that are under $80.00.
That is another way you can tell.
I wish I had that when I brought my Xigmatek 650. When I got it 2 years ago it was 149.99
now it's $99.99
Message edited by Keiki646 on 03-03-2010 at 01:33:21 AM
Reply to Keiki646
+3.3V@25A,
+5V@25A,
+12V1@25A,
+12V2@25A,
-12V@0.3A,
+5VSB@2.5A
No, no, I totally understand--sorry if it seems like I'm being difficult, I really appreciate all the input and suggestions that you and everyone else has provided, and I'm just trying to look at things from all angles.
You nailed it on the head with what you said about me being on a budget, but also not wanting to end up with a PSU that's going to fry my system. This -apparently- makes it hard to make choices, haha.
About looking at the specs on the OCZ Mod X 600PSU, what did you mean by that? What are you pointing out?
Reply to Hastibe
I wasn't talking to you about it, I was asking delluser1 to look at it.
but a PSU frying your system is a small chance (only happens when someone doesn't know what they are doing)
Message edited by Keiki646 on 03-03-2010 at 01:41:41 AM
Reply to Keiki646
P.S. Here's the list of PSUs I'm eyeing now, if my 430W PSU isn't enough:
HIGHER QUALITY
Thermaltake TR2 W0379RU 500W $40 +12V1@25A,+12V2@18A
http://www.newegg.com/Product/Prod [...] %20W0379RU
OCZ StealthXStream 600W $50 +12V1@18A,+12V2@18A,+12V3@18A,+12V4@18A
OCZ ModXStream Pro 500W $50 +12V1@18A,+12V2@18A
OCZ ModXStream Pro 600w $55 +12V1@25A,+12V2@25A
DISPUTED QUALITY(?)
COOLMAX NW-650B 650W $40 +12V1@16A,+12V2@16A,+12V3@16A
http://www.newegg.com/Product/Prod [...] 6817159082
RAIDMAX HYBRID 2 RX-530SS 530W $40 +12V1@20A,+12V2@17A
http://www.newegg.com/Product/Prod [...] 6817152028
COOLMAX CU-700B 700W $50 +12V1@18A,+12V2@16A,+12V3@16A
http://www.newegg.com/Product/Prod [...] 6817159089
COOLMAX CL-700B 700W $50 +12V1@16A,+12V2@16A,+12V3@16A,+12V4@12A
http://www.newegg.com/Product/Prod [...] 6817159107
TOPOWER ZU-550W 550W $50 +12V1@20A, +12V2@20A
http://www.newegg.com/Product/Prod [...] 6817101021
Rosewill Green Series RG530-S12 530W $55 +12V@41A
http://www.newegg.com/Product/Prod [...] 6817182199
Reply to Hastibe
HIGHER QUALITY
DISPUTED QUALITY(?)
The first one (Thermaltake TR2 W0379RU 500W) is not certified You need to look at Certified PSU
Is certified but not the best of them Rosewill I am not to used about them... the rails and quality
Best Brand name are
OCZ
Corsairs Air
Xigmatek
Cooler Master
XFX
Message edited by Keiki646 on 03-03-2010 at 01:57:01 AM
Reply to Keiki646
delluser1 wrote :
Stick with it, most of what you listed is crap
http://www.hardwaresecrets.com/article/936
See on what I have been saying all this time. Yes he went from good PSU to crappy PSU's
Best if you stick with the OCZ ModX 600
Reply to Keiki646
Okay guys, thanks for all your input--you convinced me and I went with it, just ordered the OCZ ModXStream Pro 600w off of Newegg.com! :)
Reply to Hastibe
I hope it goes well for you
Reply to Keiki646
Gday all Im in the same boat so i thought i would just post in here. Heres the system im looking at building
Intel Core i7 920
XFX Radeon HD5970 2GB
Corsair CMG6GX3M3A2000C8 6GB Kit Dominator GT
EVGA X58 SLI LE Motherboard
CoolerMaster HAF 932 Case
OCZ Vertex Turbo 60GB SSD for OS
Western Digital RE4 2TB WD2003FYYS
Pioneer BDC-202 Black Blu-Ray Combo Drive OEM
COOLING:
Swiftech Apogee XT CPU Waterblock
Swiftech MCR220-QP Stackable Radiator
Swiftech MCP655-B 12V Pump
XSPC Laing DDC Bay Res
The PSU's ive been looking at so far are:
Antec TruePower Quattro 850W
Enermax Revolution85+ SLI 850W
Silverstone Strider Plus 850W
XFX 850W Black Edition Modular PSU
Advice on any of the parts iv chosen so far would be greatly appreciated as well. Iv considered the i7 975 but my mates got his 920 running at 4.1 constantly so i dont think its worth the extra grand. Also i intent to eventually smack on another 5970 some time in the future.
Cheers in advance
Message edited by Lsrobb on 03-03-2010 at 10:17:11 AM
Reply to Lsrobb
lsrob, out of all fo those, i would go with the XFX one. I havent seen any bad reviews for the XFX power supplies yet. ( real reviews, not newegg reviews ).
Reply to Truhls
Intel Core i7 920
COOLING:
Cheers in advance
The 850W Black Edition from XFX sounds good but
I would pick Antec 850W SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Modular
http://www.newegg.com/Product/Prod [...] 6817371009
Look a this
http://images17.newegg.com/is/image/newegg/17-371-009-S03?$S640W$
Reply to Keiki646
There are 1920 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 2 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
