Speed fan does not work
  • CPUs
  • Fan
Last response: in CPUs
March 2, 2010 12:15:49 PM
Just downloaded Speed Fan and it does not recognize ANY of my fans or voltages. I really need to speed up my CPU fan speeds as my AMD athlon 64 x2 6000 3.00ghz is running under full load at around 60 to 65 degrees. I cannot access the BIOS during start up as my usb keyboard does not activate until the login screen. I do not have a ps2 port. How can I access my CPU fan speeds either on Speed fan or any other program? :heink:
More about : speed fan work
a c 133 à CPUs
March 2, 2010 12:28:10 PM
Your USB keyboard should work at bios screen. What motherboard you have are you using a dell or some other pre built?
m
l
March 2, 2010 12:58:34 PM
Yes I have a Dell Dimension C521 and it is the Original MOBO. (i dont know what kind of MOBO it is only that it has a nvidia chipset.) the items i upgraded are as follows 4gbs of ddr2 ram, amd athlon 64x2 6000 3.00ghz, scythe shrunken cpu cooler, Ultra LSP 650watt ATX ps and a EVGA 9800gt.
m
l
March 2, 2010 3:24:22 PM
And no the key board does not function untill I get to the login screen.
m
l
a c 133 à CPUs
March 2, 2010 3:29:04 PM
dell motherboards dont allow you to adjust fan speeds
m
l
March 2, 2010 4:26:08 PM
Then how can I adjust fan speeds? Like I said, speed fan does not recognize any of my fans or voltages or speeds. Is there another program that I can use since I cant change the fans speed in the Bios?
m
l
