Solved
Need to cheapen up a build
Shopping Cart contents:
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
MSI 790FX-GD70 AM3 AMD 790FX
SAPPHIRE VAPOR-X 100269VXL Radeon HD 4890 1GB
CORSAIR CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB
So far, this has me at about $900.00 CAD, before taxes/shipping.
What I'd like to do is lower the price to $750.00 - $800.00 without compromising too much power.
The reason behind this is I need to add a case, mouse, and a keyboard, and I'm a bit over budget. If you know of any good cases around $100.00, and a mouse and keyboard that, together, also don't go over $100.00, that would be great too!
Thanks!
3 answers Last reply Best Answer
More about need cheapen build
  1. Best answer
    ^ It is pretty much easy to bring the build to 750-800 range without much compromise in performance...
    CPU - X4 955
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103808
    Mobo - ASUS 790X - This board offer very good features and with good air cooling, 3.6-3.8GHz overclock is achievable...
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131402
    PSU - Even this Antec TruePower 750W is good enough for your build(Can also support 2 cards easy)
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16817371025
    These changes saves about CAD 112...
    CASE -
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119137
    KB & mice -
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16823109156
  2. And if you know you will never put in a second video card, you can save a little more by sacrificing modular cables and going with an even smaller PSU:
    Corsair 650 TX:
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139005
  3. amd phenom ii 550 be, just unlock the cores, then overclock and away u go
New Build Systems Product
