Hi
My pc was full of dust and the thermal compound was very old and the cpu temperature was little high,
So I cleaned my pc then I changed the thermal compound ( it was my first time to remove the heatsink and changing the thermal compound ) anyway before I changed the thermal compound I watched a lot of how to videos.
Then I cleaned the pc and changed the thermal compound I put on the side a 120mm fan and down the case a smaller fan
So now I have clean pc, new thermal compound and more fans, but unfortunately the cpu temperature didn't get lower it became higher on idle and load which is really strange, I changed the thermal compound four times three time I put a small dot of thermal compound in the middle and the last time I put it vertically or horizontally I don't remember.
here is a pic after playing for about 10-15min
http://img23.imageshack.us/img23/6353/newerrx.jpg
I know the thermal compound I have is not very good but it's the same one I had on my cpu for few years so it should not be the problem, I have a standard heatsink and my cpu is not overclocked
my case is cooler master haf 922
Thanks
Thanks
