Does this homebuilt system work?
Last response: in Systems
APPROXIMATE PURCHASE DATE: within the month
BUDGET RANGE: 3-4k
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, internet, movies
PARTS NOT REQUIRED: keyboard, mouse, networking stuff
PREFERRED WEBSITE(S) FOR PARTS: as of now tigerdirect.com and newegg.com (unless advised to something better)
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: AMD
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Yes
MONITOR RESOLUTION: (e.g.: 1024x768, 1280x1024, 1440x900, 1600x1200, 1680x1050, 1920x1080, 1920x1200)
ADDITIONAL COMMENTS: N/A
I have done alot of research on building a new gaming PC.. I think everything is compatiable with each other but I am a noob when it comes to building PC's.. Just looking for advice to see if I missed anything that would make some part not compatiable. Thank's in advance or the advice.. Feel free to comment if any of the parts could be swapped with something newer or better within reason..
Also opinions on the build would be greatly appreciated
Quad Core Processor - 3.40GHz, Socket AM3, 6MB Cache, 2000MHz (4000 MT/s) FSB, Retail, Processor with Fan
BFG - NVIDIA GeForce GTX 295 1792MB DDR3 PCI Express Graphics Card (may get 2)
MSI 790FX-GD70 AM3 AMD 790FX ATX AMD Motherboard - Retail Quad CFX, 4 PCIE 16slots DDR3-2000+, Exclusive OC
Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model 996657 (2 sets of these)
Cooler Master HAF 932 Full Tower Black Case
Corsair CMFSSD-128GBG2D P128 Solid State Drive - 128GB, 2.5", SATA II
Hitachi Deskstar HD32000 IDK/7K Internal Hard Drive - 2TB, 7200RPM, 32MB, SATA-3G
XION Power Real 1000W ATX Power Supply
LG GH22NS50 DVD Writer - DVD+R 22x, DVD+RW 8X, DVD-RW 6x, DVD-RAM 12x, SATA (OEM)
NVIDIA 3D Vision Bundle: Samsung Syncmaster 2233RZ 22" 3D Gaming LCD Monitor and NVIDIA 3D Vision Stereoscopic Glasses
Creative Labs 70SB088600002 SoundBlaster X-FI Titanium Fatal1ty Pro PCIe Sound Card
Cooler Master Hyper N520 CPU Cooler - Socket LGA 775, 754, 939, 940, AM2, AM2+, 1156
More about : homebuilt system work
Ok well no offense but that build is pretty horrible lol. Gimme a few min I'll put something to gether for you.
Oh and the NVIDIA 3D thing. Totally not worth the money.
MOBO/CPU Combo $573.98
I7-920 and ASUS P6X58D Premium w/ USB 3.0 and SATA 6.0
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
RAM Mushkin Enhanced Redline DDR3 1600 6-7-6-18 $239.99
HSF Hyper 212 Plus $28.83. Performs better than almost anything else on air. Though for your budget, totally consider getting water cooling.
HD's Intel X25-M 160gb $539.99
Spinpoint F3 1TB x 2 $169.98
GPU ATI HD 5970 x 2 $1339.98 (This is totally overkill btw, so you might just wanna get 1 and save some money)
Optical Drive- any $30 Sony, Liteon, LG is fine. No point in getting a Blue Ray burner really, but it's $189.99 if you do want one.
Case- HAF 932 $139.99 - One you picked is fine.
Sound Card- Don't really need one. Though the one you linked is fine i guess if you really must have one. $159.99
PSU - Corsair 1000 HX $239.99
Corsair 850HX would also work $179.99. Might be close if you wanna OC CPU and both 5970's to the max though.
Total: $3302.73
Can save lots of money by only getting 1 5970. 2 of them really is overkill for any game in existence.
Also, can consider 2x 80gb X25-M's in raid 0. However, 80gb isn't really enough for apps + OS + lots of games.
Can also get away with the 850HX if you wanna save some money.
You can also get cheaper RAM and a cheaper MOBO, but this stuff all fit sin budget easily and is quite nice.
Monitor I'd recommend 3x these Samsungs $249.99 each
Edit: The G SKills Mad linked are probably a better choice. Same speed timing and latency for less. Lower voltage too. Couldn't find em earlier >.<
Yes, everything works. That said, for the price, that build is about as crappy as it can be without being in a toilet.
For gaming, you can't beat an i5 or i7, especially with you're budget.
I'll be back with links and prices (not that they matter)...
CPU: i7-950 $570
Mobo: ASUS P6X58D Premium $300
RAM: G.Skill Trident 3x2 GB 1600 mhz CAS Latency 6 $195
GPU: Radeon HD 5970 $670
Data HDD: Samsung Spinpoint F3 1 TB x2 $170
SSD: Intel X25-M 2.5" 80GB $300
PSU: Corsair 850W Modular $180
Optical: LG 22x SATA DVD Burner $28
Cooler: Coolermaster Hyper 212 $29
Case: HAF 932 $140
Total: $2,582. Plenty of room for a monitor/OS/whatever else. You don't need a sound card. Once you pick a monitor, you can still probably afford a second GPU or more RAM. Neither is necessary.
Related ressources
so looking at the 2.. this is what i came up with.. opinions?
CPU: i7-950 $570
Case: HAF 932 $140
PSU: XION Power Real 1000W ATX Power Supply $100
and is the 3 monitor thing worth it?? granted the monitors are cheap enough.
Xion is not a respected PSU company. Stick w/ seasonic, antec, corsair, Xclio and OCZ. Also, any 1k watt PSU going for $100 is very suspicious. Actually looking at the PSU specs, it's +12V is spread over 6 rails. It's not modular and there are several rails at exactly 20amp, which means that it's probably not gonna run 2 5970's considering they require 35 amps of power each (20 amp for 8 pin, 15 for 6 pin, more if you wanna OC).
Biggest point in buying a PSU is looking at +12 amperage, not wattage. You can make a 1000W PSU that couldn't run a 5770 if it doesn't have enough +12 amperage.
Best price atm on newegg would be the Corsairs. The 850 TX Mad linked, if you only plan on getting 1 5970. If you wanna get 2 of them and OC everything to the max, you might wanna grab the 1000TX I linked.
majorhavoc said:
If your going to fork out that much money why skimp on a cpu cooler, get something like that new corsair h50 or thermalright, xigmatek, I have had great luck with corsair psu's
Because the CM Hyper 212 is one of the best performance i5 HSF's.
http://www.frostytech.com/top5heatsinks.cfm
It outperforms everything the Xigmatech HDT-S1283, which beats it by i think 0.2 degrees, but is noisier. However, as Tom's noted in their recent SBM's review, that cooler has issue with the adapter to make it work on i5's.
So, yea no point in paying for those huge overprices cooler when they work worse!
Ask the community
