Hey guys, deciding on my parts for my first water cooling build, my build as is below..
CPU: Intel i7-3770K LGA 1155
Mobo: Asus P8Z77-V Deluxe Z77 Chipset
RAM: 16GB Corsair Dominator GT @ 2100MHz and 1.5V
Case: Corsaid Obsidian 800D
GPU: GeForce 560 ti (480 core)
PSU: Corsair (not sure on the wattage yet)
SSD: 60GB for boot and high-traffic apps
HDD: 1TB storage
DVD Drvie: 24x Asus Writer/Reader
Blu-Ray Drive: 12x Asus Writer/Reader
Cooling: HELP!!!
So, as you can see, I've taken a lot of time to come up with this parts list, and spent a lot of money doing so. This being said, I definitely don't want to go mess it all up with an inadequate air system, or a poorly build water system.
I've read all of the stickies on water and air cooling, and checked out many threads. I am overwhelmed big time. I definitely want to water cool my CPU and GPU, and my board if I can (I really would like to do this too). I've read the reviews on the skinees website, and I feel that I can adequately choose a CPU block. I obviously can't find a closed-loop system that has blocks for my CPU and GPU, so I'm gonna have to go custom on this one.
First off, the case I'm getting (Obsidian 800D) is pretty roomy, and I need opinions if I should use a reservoir that fits in a drive bay (like this: http://www.google.com/imgres?um=1&hl=en&sa=N&rlz=1C1AVSX_enUS396US396&biw=1366&bih=667&tbm=isch&tbnid=q8G6aROv3dPe1M:&imgrefurl=http://www.acousticpc.com/danger_den_res-100_clear_lucite_acrylic_drive_bay_reservoir.html&docid=F5K-74dq0Y3-mM&imgurl=http://www.acousticpc.com/images/a_clear_single_525_bay_reservoir.jpg&w=250&h=205&ei=JKTzT-7rOoegrAHKn5jaAw&zoom=1)
or a standing reservoir (like this: http://www.google.com/imgres?um=1&hl=en&rlz=1C1AVSX_enUS396US396&biw=1366&bih=667&tbm=isch&tbnid=14mSCENgFaYSRM:&imgrefurl=http://www.2cooltek.com/Liquid-Cooling-Accessories/&docid=_7b8qt_eSHaVtM&imgurl=http://www.2cooltek.com/images/T/CLW0189_1__02714.jpg&w=459&h=459&ei=T6TzT6TaEZG1qAGFltDRAw&zoom=1&iact=rc&dur=324&sig=108192123136365719955&page=1&tbnh=147&tbnw=122&start=0&ndsp=18&ved=1t:429,r:16,s:0,i:123&tx=42&ty=91)
Next, I need help choosing a radiator, there are so many options my head is spinning. Should I go with one large bulky radiator, two smaller ones, or one large and one small? And also, I have no idea if I'll need a 360, 120, 180, or what size fans and how many at all. I need help with clarification here.
After that, choosing a pump is the next step. This part is relatively easy, there are a lot of pumps but it's a pretty simple concept. Any suggestions on pumps? I'm looking for a quieter pump, but I won't sacrifice efficiency for noise, so go ahead and recommend whatever.
Next: waterblocks. Choosing a CPU waterblock is straight forward, as is the block for a GPU. Find the model and chipset = you're golden. HOWEVER, as I said earlier, I want to cool my board as well, and the blocks for those are confusing as crap. Do I need a full board model, or what?
Finally, the barb and tubing system totally slips past my brain. Do the barbs on the blocks have to be the same size as both the barbs on the pump, reservoir, and conjoining blocks as well? If so, I think this would be very hard to find...
Thanks for anyone who was willing to read through this post to help me out, I really do appreciate it a lot. Please post helpful comments, suggestions, or recommendations.
Thanks!
HDD: 1TB storage
Cooling: HELP!!!
Thanks!
