So, I just landed an awesome new job and will be doing some major upgrades to my system in about two months. Among other things, I'm replacing my 2500k with a 3770k, and the 6950 with a 670 GTX (both will be water cooled). Every overclockable component will be pushed to its limit. May even try chilling the water, been dying for an embedded development project, and a chiller that stops at ambient temps sounds like a fantastic use of my free time.
Cost isn't an issue for the water cooling. I don't need the best of the best, but I want something that can handle SLI in the future without needing to upgrade too much. No interest in GPU blocks that aren't full cover. I've done some initial research, and here's what I've come up with.
CPU Block: Koolance CPU-370
GPU Block: EK-FC670 GTX (not on sale until the 20th)
Radiator: Black Ice GTX 240 Radiator (can't fit 360mm in my case)
Reservoir: XSPC Acrylic Dual 5.25”
Pump: Swiftech MCP35X
A bit pricey, and probably overshooting what I need by a bit. But hey, why work so hard if you're not going to play just as hard, right? If I can save some money and not lose performance, that's fine, but I don't want to cut corners if it will limit my max overclock.
I'm least sure about the reservoir. Seems like it would have little impact on the overall performance, beyond needing a certain capacity. If there's a good reason to get a different res, I'm open to it. The pump needs to be able to handle a second GPU block (single loop) in the future.
As far as fans, I haven't done my research yet, but it seems like Yate Loons are the way to go. I've currently got a pair of Cougar 120mm fans, which are dead silent but I'm not sure about their static pressure. I'm willing to pay a premium for silence, and the high performance Yate Loons at 40dB are a touch loud for my tastes. I'd be thrilled if I could recycle my Cougars, but if they aren't suitable to pushing through a thick radiator, they'll be replaced.
