I just purchased all of my parts for my new build on the egg except for the last piece... a CPU cooling solution
Budget is $300 US but less cost is better if it satisfies the requirements
CPU: i7 3770k
Target OC: 4.5 GHz
Case: CoolerMaster HAF X 942
Mobo: ASUS Sabertooth Z77
RAM: 16 GB Corsair Vengeance (4GBx4)
Graphics: EVGA GTX 670 4GB version
All other components of the build seem irrelevant to me but if you need them I will provide them
Just looking for a great cooling solution for my new comp preferably with some nice aesthics and glowy awesomeness, DOES NOT HAVE TO BE WATERCOOLED.
Also if watercooling is recommended I will be using DI water because its free from work.
Final Note: the kit and or components need to be in stock so I can actually buy them in the next 24 hours
CPU: i7 3770k
Target OC: 4.5 GHz
