Hello,back to life?
iomega portable HD not showing (2TB)
under "MyComputer"
But shows up in device manager.
any utilities around to bring it back to life
1. Try to connect to a different USB Port on your PC
2. Could you check if this HDD shows in some other computer
3. Make a CD of Parted Magic and boot from CD. You don't have to install. See if your HDD is visible and you get access to your data and are able to save.
