Hi,
This is my first post and im new to this forum!
Im new at building a computer and im trying to build a fairly decent gaming computer for a low budget.
I am on a tight budget of 200 - 300$ and 300$ is pushing it.
I was wondering if this is decent (?) :
MotherBoard: GIGABYTE GA-MA78LM-S2 AM3/AM2+/AM2 AMD 760G Micro ATX AMD Motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128407&cm_re=gigabyte_motherboard-_-13-128-407-_-Product)
CPU: AMD Athlon II X2 250 Regor 3.0GHz 2 x 1MB L2 Cache Socket AM3 65W Dual-Core Processor (http://www.newegg.com/Product/Product.aspx?Item=N82E16819103681&cm_re=amd_athlon_ii_x2-_-19-103-681-_-Product)
RAM: Crucial 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model CT2KIT12864AA800 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820148163&cm_re=ddr2_800_crucial-_-20-148-163-_-Product)
Gfx card: ZOTAC ZT-96TEY3G-FSL GeForce 9600 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (http://www.newegg.com/Product/Product.aspx?Item=N82E16814500117&cm_re=Geforce_9600GT-_-14-500-117-_-Product)
- are there any better gfx card for 100$~ ?
- And is that motherboard/chipset good for gaming?
- will that cpu fit in that mobo?
I also have a 400 watt powersupply that came with a cheap case.
Thank you so much!
Thank you so much!
