Hi there,
I'm looking for a computer case that fits the following criteria:
-as small as possible for a standard size motherboard
-as cheap as possible
-will allow me to leave it on all the time, with fans that ONLY come on when the computer actually gets hot. Basically, I want it to be quiet, but by quiet I mean I would prefer not for the fans to come on at all unless I am actually using it for something intensive - which will not be very often as I am using it primarily just to download and play movies.
Thanks in advance for your help... as you can tell I am not exactly a computer guru, and information woujld be greatly appreciated thank you!!
