Thoughts on First Water Cooling Setup?
I know this might be a little overpowered since I'm only cooling the cpu but im low on money so money is tight but i will add on later. Anyways here's the setup tell me what you think and if all the components are compatible. I spent a lot of research on water cooling. Thanks!
Pump:
Koolance PMP-400 3/8" ID Native Liquid Cooling Pump (PMP-400)
http://www.frozencpu.com/products/16591/ex-pmp-201/Koolance_PMP-400_38_ID_Native_Liquid_Cooling_Pump_PMP-400.html
Radiator:
Alphacool NexXxoS ST30 Full Copper Slim Profile Quad 120mm Radiator
http://www.frozencpu.com/products/15666/ex-rad-375/Alphacool_NexXxoS_ST30_Full_Copper_Slim_Profile_Quad_120mm_Radiator.html
CPU Block:
EK Supremacy Universal CPU Liquid Cooling Block - Acetal (EK-Supremacy - Acetal)
http://www.frozencpu.com/products/16251/ex-blc-1131/EK_Supremacy_Universal_CPU_Liquid_Cooling_Block_-_Acetal_EK-Supremacy_-_Acetal.html
Tubing:
2.5 Meter (8 feet) Feser Tube Active UV Hose - Retail Packed - 3/8" ID (1/2"OD) Anti-Kink Tubing - UV Light Blue
http://www.frozencpu.com/products/8662/ex-tub-454/25_Meter_8_feet_Feser_Tube_Active_UV_Hose_-_Retail_Packed_-_38_ID_12OD_Anti-Kink_Tubing_-_UV_Light_Blue.html
Clamp:
1/2" OD Reusable Clamp - Black
http://www.frozencpu.com/products/5390/ex-tub-135/12_OD_Reusable_Clamp_-_Black.html
Barbs:
Alphacool G1/4 Thread 3/8" (10mm) ID FatBoy Barb - Deep Black
http://www.frozencpu.com/products/15238/ex-tub-1212/Alphacool_G14_Thread_38_10mm_ID_FatBoy_Barb_-_Deep_Black.html
Reservoir:
EK Dual Bay SPIN Reservoir w/ Flow Meter - Acetal Black
http://www.frozencpu.com/products/8584/ex-res-146/EK_Dual_Bay_SPIN_Reservoir_w_Flow_Meter_-_Acetal_Black.html
The reason why i'm not cooling the GPU yet is because I might be getting 2 27 inch monitors for a dual monitor setup and I'll buy another GPU which is the ATI 6850.
Thanks for looking over these parts and giving me advice. Please be gentle as this is my first attempt at putting together a water cooling setup.
1 answer Last reply
More about thoughts water cooling setup
  1. Also my case is a HAF 932.
Water Cooling CPUs Overclocking
