Power supplies are not rated for a constant amount of power that they force into your computer. They are rated for a constant voltage and a maximum power. Components cannot tell the difference between a 200W and a 20kW PSU as long as the components draw less than 200W. They will just see the PSU as a voltage source, and draw as much power as they need. The only difference between the 200W and 20kW PSU is that if your components draw more than 200W, the 200W PSU could shut down, go out of spec, or even destroy itself trying to supply >200W, while the 20kW PSU will happily continue along.
This also means that if you went out and bought a huge, 2kW PSU for your computer and then hooked it up to a power meter, it would likely only be pulling a couple hundred watts under full load. This is because your computer is only using as much power as it needs, regardless of PSU size.
