O.K., Brand new build using Intel i7-860. First off, love the system! One glitch – Zune 30 causes VERY slow POST and performance problems if I boot with the Zune device connected. Once in Windows, 2D graphics benchmarks 3X faster, but system is unstable and slow. Normal boot and performance without Zune attached.
ASUS graciously replaced the mobo, which solved an Express Gate problem, but the Zune problem has not gone away. All other USB devices play fine.
Configuration:
P7P55D Premium
Windows 7 Professional 64 bit
Corsair CMPSU-750HX 750 Watt Power Supply
Kingston 64 GB SSDNow V Series SATA Boot Drive
Sapphire 100283L Radeon HD 5770 GPU
Intel Core i7-860 Lynnfield LGA 1156 Quad Core CPU
WD 15EADS 1.5 TB SATA
Seagate LP ST3200542AS 2 TB SATA
Rosewell RCR-IM5001 USB 2.0 75 in 1 Card Reader w/ eSATA Port
Kingston HyperX 4GB (2X2GB) 240 Pin DDR3 SDRAM 1600 (PC3 12800) Memory
LG GH22LS50 SATA LightScribe DVD
Note – Problem begins during POST when Zune is attached, so it’s not an OS problem. Suspect a conflict between the Zune and the Sapphire Radeon HD 5770.
Anybody else having similiar problems? Anybody found a solution?
Configuration:
P7P55D Premium
