So here's my setup for it and i'm cooling the CPU and the GPU.
Koolance PMP-400 High-flow Pump
$69.99
EK-VGA Supreme HF Bridge Edition - Acetal
- Fitting Size 3/8" Barb for 3/8" ID tube
$65.95
Swiftech APOGEE HD Ultimate Extreme Performance Water Block - Black
$69.99
X-Flow Black Ice Pro III High Performance Radiator - Black
- Fitting Size 3/8" OD
$56.95
Koolance Tubing, Blue UV-Reactive PVC, 1ft/30.5cm [ID: 10mm (3/8"); OD: 13mm (1/2")
$13.90
Bitfenix Recon 5 Channel Mobile Device Controlled Fan Controller
$39.95
EK-BAY SPIN Reservoir - Plexi
$64.94
Alphacool 10mm (3/8") Barbed Fitting G1/4 with O-Ring "FatBoy" - Deep Black
$29.90
Total: $411.57
Tell me if the barbed fittings and all of these items are compatible with each other Thanks!
I also liked to mention that i have a HAF 932 case.
$69.99
$65.95
$69.99
$56.95
$13.90
$39.95
$64.94
$29.90
Total: $411.57
