Remove Product(s) Qty. Total
NZXT Sentry 2 - 5.25" Touch Screen Fan Controller - Black
$29.95
IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
$6.99
XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting - Chrome Finish
$11.97 quanity: 3
XSPC Raystorm Extreme Universal CPU Watercooling Kit w/ EX360 Radiator/DDC Pump/Res
- CPU Waterblock XSPC Raystorm - Intel
- LED Color Blue
- XSPC 120mm Radiator Fans XSPC 120mm 2000RPM Fan
- Fitting Size 1/2" x 3/4"
- Compression Fitting Color Silver Chrome Finish
- Tubing 2M (6.5')' Water Tubing - UV Blue
- Coolant No Coolant
- Reservoir XSPC Dual 5.25" Bay Reservoir for Single Laing DDC
$252.99
PrimoFlex Pro LRT UV Blue Tubing -1/2in. ID X 3/4in. OD
$22.50
Sub-Total: $324.40
I might add a GPU Block in Later thanks for opinions
Shoutout to Amuffin for helping me.
$29.95
$6.99
$11.97 quanity: 3
- LED Color Blue
$252.99
$22.50
Sub-Total: $324.40
