Well, I'm still in the process of building this new system. Decided to go with the i5-750 (although I'd easily upgrade to the K series, if they decide to do a K of the 750), and we're shopping around for mobo's. Future-proofing is nice, but not essential, and I've pretty much made up my mind to go with the ASUS P7P55D-E series, just due to the SATA 6 and USB 3 options. One less thing to pop open the computer for later.
The real problem is that I'm stuck between the P7P55D-E Deluxe and Premium editions. Both have the exact same feature set, but the Deluxe is pegged as a 'Hybrid' board on the website. It says it's a 16+3 Phase power design, while the Premium is a 32+3.
I have some guesses, but I'm really not sure what the difference is. I assume that a higher number gives more power (ie, more constant speed, more heat), but I'm not really sure what the pro's and cons are. I'm running an air-cooled, 3-fan Anitec P180, and the computer runs pretty much 24/7, with occasional breaks here and there (run a couple fileservers and a website off of it in the background).
Could someone please explain the pros and/cons of going with a higher 'phase power'? I'm pretty geeky, but if you could put it in layman's terms, that would be fantastic.
