First build help
I was thinking about doing a build using these pieces. Its my first build and am not really that sure how compatible these are. Any suggestions are welcomed thanks.
processor: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
Mobo: ASUS M4A78 Plus AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.303790 =$224.99
Case: XCLIO Blackhawk Black Finish 0.8 mm SECC / ABS Plastic ATX Full Tower Extreme Cooling Computer Case - Retail
PSU: XCLIO GREATPOWER X14S4P4 750W ATX12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.303751 = $185.98
HDD:
SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152102 = $84.99
GPU: HIS H585F1GDG Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card w/ATI Eyefinity - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161302&cm_re=hd_5850-_-14-161-302-_-Product =$314.99
Memory:
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Desktop Memory Model CMD4GX2M2A1066C5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145256 =$104.99
Total = $915.94
Are there any problems anyone notices with this configuration or ways to up the performance without spending too much more. Thanks again for all your help
1 answer Last reply
More about first build help
  1. GreatPower is a tier-2 PSU. Excellent choice.
    The mobo is crap though. I'd spend a bit more for a SB750 chipset.
    1.
    newegg show details
    newegg hide details
    Model
    Brand AMD
    Processors Type Desktop
    Series Phenom II X4
    Model HDZ955FBGIBOX
    CPU Socket Type
    CPU Socket Type Socket AM3
    Tech Spec
    Core Deneb
    Multi-Core Quad-Core
    Name Phenom II X4 955 Black Edition
    Operating Frequency 3.2GHz
    Hyper Transports 4000MHz
    L2 Cache 4 x 512KB
    L3 Cache 6MB
    Manufacturing Tech 45 nm
    64 bit Support Yes
    Hyper-Transport Support Yes
    Virtualization Technology Support Yes
    Voltage 0.875V - 1.5V
    Thermal Design Power 125W
    Cooling Device Heatsink and Fan included
    Manufacturer Warranty
    Parts 3 years limited
    Labor 3 years limited
    2.
    ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail newegg
    2. ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail
    newegg show details
    newegg hide details
    Model
    Brand ASUS
    Model M4A79XTD EVO
    Supported CPU
    CPU Socket Type AM3
    CPU Type Phenom II / Athlon II / Sempron 100 Series
    FSB 2600MHz Hyper Transport (5200 MT/s)
    Chipsets
    North Bridge AMD 790X
    South Bridge AMD SB750
    Memory
    Number of Memory Slots 4×240pin
    Memory Standard DDR3 1800(O.C.) / 1600 / 1333 / 1066
    Maximum Memory Supported 16GB
    Channel Supported Dual Channel
    Expansion Slots
    PCI Express 2.0 x16 2 (one x16 or dual x8 link)
    PCI Express x1 2
    PCI Slots 2
    Storage Devices
    PATA 1 x ATA133 2 Dev. Max
    SATA 3Gb/s 7
    SATA RAID 0/1/5/10/JBOD
    Onboard Video
    Onboard Video Chipset None
    Onboard Audio
    Audio Chipset VIA VT1708S
    Audio Channels 8 Channels
    Onboard LAN
    LAN Chipset Realtek 8112L
    Max LAN Speed 10/100/1000Mbps
    Rear Panel Ports
    PS/2 2
    USB 1.1/2.0 8 x USB 2.0
    IEEE 1394 1 x IEEE 1394a
    eSATA 1 x eSATA 3Gb/s
    S/PDIF Out 1 x Optical
    Audio Ports 6 Ports
    Onboard USB
    Onboard USB 2 x USB connectors (4 ports)
    Onboard 1394
    Onboard 1394 1x 1394a
    Physical Spec
    Form Factor ATX
    Dimensions 12.0" x 9.6"
    Power Pin 24 Pin
    Features
    Features New-Gen. 8+2 Phase Power Design
    EPU
    TurboV
    Turbo Key
    ASUS Anti-Surge Protection
    Support ATI CrossFireX technology
    newegg
    1. AMD HDZ955FBGIBOX: $165.00
    2. ASUS M4A79XTD EVO: $119.99
    Combo Discount: -$20.00
    Combo Price: $264.99
    $10.00 Mail-In Rebate Card pdf
    Price After Mail-In Rebate(s): $254.99
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.303822
    And get a cheaper ram kit. This:
    OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK - Retail
    * Cas Latency: 7
    * Timing: 7-7-7-16
    * Voltage: 1.5V – 1.6V
    * Your Price:$79.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820227346&cm_re=ddr3_4gb-_-20-227-346-_-Product
    Practically no change to your total price, but this mobo is the envy of every overclocker.
Homebuilt Build Systems Product
