I am looking to watercool my fractal arc mini. Right now I looking for a power supply that is short enough to allow me the use of the bottom fan mount. I would like to know if optical bay resevoirs/pumps are sufficient for a full watercooling setup. If they are not powerfull enough then I can just get any powersupply because the bottom of my case will be where i would need to put my pump/res. Unless there are other options I am not seeing?
http://www.fractal-design.com/img_prod/FD-CA-ARC-MINI-BL_2.jpg
I am planning for a 240mm top, maybe a double thick 120 with push pull in the front and if I can put the pump/res in the optical bay then I will put another 120 at the bottom.
I will be watercooling an asus top 680 and 2500k but I may buy a 690 in the future(if I can find one haha). I definitely want to overclock and want silent rads/fans. Which means low FPI?
What do you guys think? My main question is the bay pump/res.
